92 honda accord overheating
Old Oct 9, 2013 | 04:10 PM
Repeated overheating will insure you have a head gasket problem.
Your statements have nothing to do w/ overheating.
What obd1 code was presented when CEL came on?
Old Oct 10, 2013 | 09:30 PM
Haze1092's Avatar
the cel is because an o2 sensor i know this becuase i checked it and because the light doesnt come on right away i know its the o2 sensor i was wondering what could cause unburned gas on the wires. But i think the overheating problem is the head gasket
Old Oct 11, 2013 | 03:08 PM
I'm not sure what you mean by "unburned gas on the wires"?
Have you replaced the thermostat? I know you say it opened but that doesn't mean it is not sticking.
Old Oct 13, 2013 | 10:23 PM
Haze1092's Avatar
well im going to replace thermostat with radiator just to make sure and theres residue on spark plug wires its just a little bit i thought it was oil i replaced the valve cover gasket and still saw it then i smelled it and it smells like gas
Old Oct 23, 2013 | 05:45 PM
Haze1092's Avatar
ok now i did the radiator bled the coolant replaced top n bottom hose with thermostat and gasket. I start it up it goes to warm after like 2 mins stay there for like 10 mins goes up a little stays there for like 5 mins then goes all the way up before the h. It doesnt hit the h now. it stays a little under the h and goes down a little when i drive then i stop it goes back up. And i started it up with the heater on earlier it didnt blow out hot air till the temperature was all the way up its not suppose to take that long. Anyone had this problem? I dont want to give up
Old Oct 23, 2013 | 09:22 PM
Is coolant reservoir bubbling? This would indicate exhaust gas entering coolant and bad head gasket.
Old Oct 23, 2013 | 10:39 PM
  #17
Haze1092's Avatar
it doesnt seem to be
Old Oct 27, 2013 | 12:12 AM
  #18
Haze1092's Avatar
i feel like its somethin small because the temperature goes down when i drive this is a headache
Old Oct 27, 2013 | 05:42 AM
  #19
I'm getting confused here. This thread started out with the temp is fine sitting still, goes up when you drive - to now - the temp goes down when you drive?
Have you tested/checked for a head gasket leak?
You say BOTH rad fans are on 100% of the time - do me a favor and place your hand between the rad and the engine - is the air being pulled from the front of the car towards the engine?
Old Oct 29, 2013 | 09:30 PM
  #20
Haze1092's Avatar
ok let me make it clear when sitting still it goes a little pass normal just slightly and stays there. It gets hot faster when i start to drive it stays a little pass normal. Then it goes down to normal then a little pass normal. When i stop it starts going all the way up under the h. Then when i pull off again it goes a little under that. And stays there until i stop again. So basically when i drive it stays a little above normal when i stop it goes up. And it just keeps going up and back down but never back to normal temperature
goudge74
Aug 30, 2007 11:59 AM
92HARLEMHONDA
Nov 13, 2006 10:48 PM
Joshporsche
Sep 7, 2006 01:39 AM
Joshporsche
Jun 14, 2006 10:07 PM
copa708
Apr 24, 2006 08:36 PM
