93 Accord gaskets
Old Jul 7, 2020 | 06:15 PM
steve747's Avatar
Default 93 Accord gaskets
Hello. I am having trouble getting gaskets for my 93 Accord. One is the oil pan gasket. Honda wants to charge me $176 for it. Is there any alternative part number that is reasonably priced? Also if I change the gasket then I will have to remove the exhaust from the manifold. Honda says it is not showing an exhaust flange gasket on their drawings. It is a sort of triangular shape with 3 stud holes. Anyone have a part number for this? Lastly I need the small oil seal that goes inside the distributor over the shaft. The number I have is BH3888E, of course Honda doesn't recognize that number. It seems this is not available anywhere in Australia. Thanks everyone.
Old Jul 8, 2020 | 11:36 AM
Here in USA you can get Felpro gaskets that work OK. I don't know what car-parts stores you have down-under...
It seems like with a 27 year old car the aftermarket parts usually take over from the dealer anyway. If you have certain aftermarket brands available, someone here might recognize a brand & give you a judgement of good or bad?
Honda won't recognize anything about the seal for the distributor because they have never sold that separately. They want you to buy a new distributor. There's a couple different distributors, and I'm not sure if all of them have oil seals that can be found even here. I never had to do that when I owned Accords, but other guys here might be able to help if you have a part number (or photo) of the distributor.
Old Aug 1, 2020 | 12:01 AM
nomad2020's Avatar
you can buy the seal kit at e-bay kit # BH3888 around 9-10 dollars ,,, Just want the inner seal BH3888-EO
assuming you can get part from e-bay in Australia
MikeT
Mar 5, 2015 07:12 PM
crispin
Jun 4, 2012 02:09 PM
MichaelT1960
May 9, 2010 02:00 PM
ddavisso
Oct 6, 2007 08:12 PM
Herk
Sep 11, 2007 04:23 PM
