99 accord stalls after 15 minutes
I have searched a bunch off threads but still no answer? here is the problem, My sons 99 accord (4cyl) shuts down after 15 to 18 minutes idling or about 7 miles of driving.
Replaced the following:
Main Relay
Fuel Pump & Strainer,Filter
Intake manifold sensor (filled with oil)
Distributor ( Rebuild) + tried old Ignition module again
MAP sensor
Cam Sensor
Catalytic converter kept old CAT 2 sensor (looked fine)
I cleaned the throttle body, engine started for a 30 seconds a couple times before stopping again. It takes about 30-45 min to restart engine. The temp gauge looks normal although after car warm up I notice the top hose is hot as heck and bottom radiator hose slightly hot/warm. I also hear girgaling noises in the engine after shut down. Then wait for cool down and restart car starts and runs smooth until it shuts down again?????
Main Relay
MAP sensor
Cam Sensor
Baztaz
Mar 2, 2014 10:24 AM
94_Accord
Jul 30, 2013 09:49 PM
BitBucket
May 29, 2011 04:07 PM
egonzal24
Dec 8, 2007 12:08 PM
