Accord '93 EX Cooling System
Old May 2, 2006 | 05:00 PM
OldFox
Default Accord '93 EX Cooling System
Greetings,
Just wanted to know if there is a bleeding valve in the block to purge out any captive air in the cooling system in the Honda Accord '93 engine.
I replaced the upper redaitor hose and as you know you lose some coolant.
Thanks,
OldFox
Old May 2, 2006 | 06:16 PM
legionofone's Avatar
Default RE: Accord '93 EX Cooling System
fill it up... run it for a second... with the cap off the radiator... put some more into it... run it again... and wait untill it completely tops off and ur should be good... (this should be done when the engine is COLD not hot... bad things happen if its hot)
Old May 2, 2006 | 09:15 PM
deserthonda's Avatar
NO NO NO.....no need to start car, there is a nipple on top of t-stat housing ( bleeder screw )
you need a 12 mm socket to loosen it up,
loosen the nipple . put coolant in radiator
till it comes out, no air bubbles, tighten the nipple, top off radiator , install cap , you are done .
Old May 2, 2006 | 11:02 PM
or u know do that cuz hes much smarter than me ... desert likes the 5th step :-P
Old May 3, 2006 | 10:39 AM
RTexasF's Avatar
Super Member
Actually he just knows what he's talking about.
Old May 4, 2006 | 04:58 PM
OldFox
Greetings,
Many thanks to all,
regards,
OldFox
nismoawan
Oct 13, 2011 11:40 PM
Hondalover
Apr 4, 2011 04:31 PM
Anse
Jun 6, 2009 05:09 PM
nicolaselias
Mar 24, 2008 12:12 PM
mike84Accord
Dec 17, 2004 03:58 PM
