Accord keeps stalling after running a bit
Old Jan 3, 2020 | 02:07 PM
Latinking72's Avatar
Default Accord keeps stalling after running a bit
I have a 2000 Honda Accord Lx 2.3L after starting it and warming it up I’ll start to drive it and not long after driving it the car bogs down and shuts off. I already replaced the following
timing belt kit
crank position sensor
injectors
fuel pump assembly
egr valve
ignition igniter
ignition coil
main relay
map sensor
fuel regulator
Now I had it in the shop to see if the garage can figure it out they tried the ignition switch and the same thing kept happening after my car being at the shop for 4 days they couldn’t figure it out. Has anyone had this issue and fixed it or does anyone have any advice on how to fix it. It’s got me and a lot of people stumped
Old Feb 10, 2020 | 01:54 PM
slobjones's Avatar
LatinKing, have you replaced the ignition switch or just had the shop check it? That's my next task with my 1997 Accord DX 5-speed (223,000 miles). The sudden stalling condition has existed for about a year. I initially took the car to the shop and they reported no codes and gave it back to me.
I've replaced the main relay and distributor cap and rotor and see you've replaced many more parts. About the only part you haven't mentioned is the ECU (computer), which comes up in this thread: https://www.hondaaccordforum.com/for...al-loss-66042/.
Honda recalled the ignition switch (https://repairpal.com/recall/02V120000) for my vehicle and records show the switch was replaced in 2005. From what I'm reading, Part #35130-SY8-305 replaces the original, defective, #35130-S30-003. The recall covered 97-99 Accords, so would not apply in your case.
For what it's worth, the local Honda dealer tells me the stalling problem is almost always related to the main relay or ignition switch.
Levoy Bankson
Dec 21, 2017 06:51 PM
isaac_ast
Aug 20, 2012 07:50 PM
ladd
Nov 1, 2011 08:27 PM
beaver24
Jun 13, 2011 01:34 PM
oneloudskunk
Aug 14, 2009 08:27 AM
