Big Problem need help!
Old Apr 3, 2007 | 05:00 PM
BIGGS01ES
Default RE: Big Problem need help!
ORIGINAL: deserthonda
it is not the timing belt issue.......
remov ethe top cover of the fast idle valve, 3 phillip screws, get a regular screwdriver and turn in the inner valve ,, if it is ok or it still the idle surges.. than remove the top cover of the air boost valve and chk to see if the rubber diaphram leaks
OK did this to the fast idle valve and the air boost valve, still surges. I started messing around and pulling wires off of sensors to see if it would change, the only sensor that made it stop surging was the one on the firewall side of the throttle body itself.....could this be my problem? I should note that when i pull this wire off of the sensor it doesnt surge but it idles at 2000 RPM. The idle screw is all the way in too.
Old Apr 3, 2007 | 05:14 PM
sir_nasty's Avatar
I think that's an airflow sensor but I don't recall test procedures on it.... I'll try to remember to check my manual after lunch but if it was messed up it does make sense that you could get a surging idle.....
Old Apr 3, 2007 | 05:41 PM
BIGGS01ES
ORIGINAL: sir_nasty
I have read about every post related to surging idle and have tried everything suggested, asside from a mysterious vacuum leak that im not finding, this sensor is the one thing i have not changed, i believe it is the TPS
Old Apr 3, 2007 | 09:56 PM
sir_nasty's Avatar
does that TPS have a cover page? okay so it's not as funny the second time.... but anyway you could be right, I can't find it as a single piece on hondapartswarehouse.com so I'm not going to be much help....
Old Apr 3, 2007 | 10:06 PM
BIGGS01ES
ORIGINAL: sir_nasty
LOL...yeah well just for kicks i am going to the junkyard yet again to get parts. That sensor doesnt even bolt/screw on it is rivited on. This is very frustrating. Thanks for your effort, i appreciate it, james
Ankit
Feb 7, 2010 02:43 PM
bdawn8403
Feb 1, 2008 08:03 PM
blackex19
May 1, 2007 03:26 AM
sssexy70
Apr 24, 2007 03:24 PM
kramrkixass@yahoo.co
Nov 26, 2005 12:42 PM
