Brakes
Old Aug 26, 2013 | 08:12 AM
96hondaaccord's Avatar
Default Brakes
I was wondering if any of you know the common place for a leak to occur in the Brake system. I have a massive leak, but can not tell where it is coming from. The fluid is leaking from the drivers side of the car more towards the firewall. The fluid is leaking rapidly and I am nervous to drive the car, but it is my only car. I have to keep the brake fluid topped off all the time. I do not see any leaks coming from the Master Cylinder or around that area. Any ideas or suggestions would be appreciated.
Old Aug 26, 2013 | 10:06 AM
MysticBlueEX's Avatar
Almost A Senior Member
Don't drive it.!
My rear brake line rusted out, started with a tiny pinhole, just a couple of drops, I added fluid. Once. Didn't think much of it.
Then shortly after, it went, I only had 1 mile at 25 mph before I had no braking at all and had to have it towed.
Old Aug 26, 2013 | 10:11 AM
One more time,
Get it towed!
Old Aug 26, 2013 | 04:22 PM
Are you going to fix it or take it to a shop?
Lift the car & support it properly so it doesn't fall on you. Have a helper to pump the brake pedal while you watch underneath. Then you'll have a better chance to find where the fluid is actually coming from.
I wouldn't be surprised if it's a brake line (steel tube) that has corroded through. If so, then you can imagine that all the brake lines are about the same age and the same corrosion environment.
Old Aug 26, 2013 | 04:33 PM
I took a picture and it coming from the part with four brake lines connected to it. It is below all those hoses and it is below the Master Cylinder mounted to the drivers side fender well and I can see brake fluid all over the fender well where that part is mounted too. See attached picture. Does anyone know what that part is?
Old Aug 26, 2013 | 05:11 PM
Attachment didn't come thru?
You might have to resize/compress it for it to "upload" as there are size (kb) limits on files.
Old Aug 27, 2013 | 11:25 AM
I am sorry I did attach it to the original post.
Old Aug 27, 2013 | 02:04 PM
I think it's a proportioning valve. Which is different whether or not your car has ABS. (Accord LX was available with or without ABS that year)
Old Aug 27, 2013 | 03:45 PM
Mine is non-abs and also could it be possible it is one of the lines going into that proportioning valve. I can see the brake fluid on the wheel well where it is mounted too. Do you have a part number for it?
Old Aug 28, 2013 | 04:32 PM
Go to www dot hondaautomotiveparts dot com
(there's also some other on-line parts places you can choose)
click PARTS
put in your car's information
category is "brake lines" or "brake pipes" or something like that.
Seems to me the first thing for you to check is whether it's a loose fitting or something like that, rather than a failure in the proportioning valve itself.
Got a "flare wrench"? It's like a box wrench with a saw-cut through the box. That'll work much better than a typical open-end wrench on those fittings.
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
