change from auto to man. in 88 Accord
1. 5 speed transmission
2. 5 speed starter
3. 5 speed shifter assembly w/ shifter cables
4. 5 speed drivers side axle
5. 5 speed intermediate shaft
6. 5 speed clutch pedal assembly
7. 5 speed brake pedal arm
8. Clutch master cylinder w/ reservoir and lines
9. Clutch line from Clutch master cylinder to clutch dampener
10. Clutch dampener assembly
11. Clutch line from Clutch dampener to 5 speed tranny
12. Clutch line from 5 speed tranny to slave cylinder
13. Slave cylinder
14. Clutch
15. Flywheel
16. 5 speed mount
17. 5 speed mount bracket
2. 5 speed starter
13. Slave cylinder
14. Clutch
15. Flywheel
16. 5 speed mount
1988 probably has a cable clutch, not hydraulic??
If you have a shop do it for you, you probably cant afford it.
If you do it yourself, just be careful NOT to figure out how many hours it takes. You figure your time is worth maybe 20 cents per hour?? (Time is money?)
If you look at it like a fun hobby, then it could be a nice project.
(Time aint money, unless youre gettin paid)
62maxx
Oct 18, 2015 08:20 AM
88lxaccord3152
Aug 13, 2009 01:37 PM
62maxx
Oct 8, 2007 10:00 AM
