change from auto to man. in 88 Accord
Old Nov 3, 2008 | 11:30 AM
88AccordLX3152's Avatar
Default change from auto to man. in 88 Accord
What do I need to get to change out my transmission from an auto to a man.?
Old Nov 3, 2008 | 11:33 AM
Default RE: change from auto to man. in 88 Accord
1. 5 speed transmission
2. 5 speed starter
3. 5 speed shifter assembly w/ shifter cables
4. 5 speed drivers side axle
5. 5 speed intermediate shaft
6. 5 speed clutch pedal assembly
7. 5 speed brake pedal arm
8. Clutch master cylinder w/ reservoir and lines
9. Clutch line from Clutch master cylinder to clutch dampener
10. Clutch dampener assembly
11. Clutch line from Clutch dampener to 5 speed tranny
12. Clutch line from 5 speed tranny to slave cylinder
13. Slave cylinder
14. Clutch
15. Flywheel
16. 5 speed mount
17. 5 speed mount bracket
Old Nov 3, 2008 | 12:48 PM
finch13's Avatar
aka Time & Money, my two enemies.
Old Nov 3, 2008 | 01:07 PM
1988 probably has a cable clutch, not hydraulic??
If you have a shop do it for you, you probably cant afford it.
If you do it yourself, just be careful NOT to figure out how many hours it takes. You figure your time is worth maybe 20 cents per hour?? (Time is money?)
If you look at it like a fun hobby, then it could be a nice project.
(Time aint money, unless youre gettin paid)
Old Nov 3, 2008 | 01:26 PM
ORIGINAL: JimBlake
thats true, i just took a list made for the 5g accord to give him an idea.
Old Nov 3, 2008 | 10:40 PM
sweet and i have been told that a hydraulic clutch is better because it will fit or somthing like that
Old Nov 3, 2008 | 10:43 PM
just b18 swap and hydraulic swap it
62maxx
Oct 18, 2015 08:20 AM
deadaccord92
Nov 17, 2010 10:05 PM
88lxaccord3152
Aug 13, 2009 01:37 PM
demoniam
Aug 10, 2006 04:15 AM
