Cruise Control Not Working.
Old Apr 6, 2016 | 01:28 PM
SystemKhaos's Avatar
Default Cruise Control Not Working.
I have no idea what to do or what to check in order to find out why my cruise control isn't working. I'll be checking the fuse in a few minutes. Any other suggestiond if the fuse is ok?
Old Apr 6, 2016 | 01:35 PM
shipo's Avatar
Stating your make, model, engine, transmission, and model year would be helpful.
Old Apr 7, 2016 | 12:01 PM
It's a 1993 Honda Accord with the F22A1 motor. 5 speed manual trans. It's all standard from factory.
Old Apr 7, 2016 | 06:51 PM
There are several things it could be.
Did it ever work since you had the car?
Can we assume the main switch lights up but when you go to set it NOTHING happens.
Simple visual checks, is the cruise cable connected to the throttle body. Is the switch on the clutch pedal properly seated (closed) when the clutch is not pressed.
Old Apr 10, 2016 | 05:56 PM
It hasn't worked since I got the car and the switch does NOT light up. And I cannot find a fuse in the box under the hood for it.
mtrapuzz
Mar 2, 2010 05:49 PM
jmtdaddy
Nov 11, 2009 04:29 PM
russler01
Feb 23, 2008 12:19 PM
aatc20
Sep 25, 2006 04:28 PM
wskipper
Nov 19, 2005 03:49 PM
