Drive axel vibration
I have a 1995 Accord - 4cyl, automatic with 110K on the clock. Recently I elected to have the drive axels replaced since the boots were rotted and I wanted to be proactive. Since I had the axels changed I notice a vibration in the drive train during right hand turns when the transmission upshifts from 1st. to second. The vibration is also noticeable while driving straight from a full stop, again when the transmission upshifts from 1st into second gear.
This is a new problem, the vibrations were not there until I changed to drive axels. My mechanic put in a second set to see if the first set was out of balance, the second set is at least as bad as the first. I might mention that the replacement axels are Chinese supplied by Cardone - could that be the problem?
Anyone else experience similar problems?
- New axles are better (as in less likely to cause wobbles and vibrations) than Remanufactured axles which are better than Rebuilt axles.
- Not all "new" axles are created equal. Autozone, Car Quest, Pep Boys, et al. seem to have a spotty reputation even with their highest quality (most expensive) axles; some folks have no issues, others have had to replace axles several times before the get the vibration issues solved.
- Honda axles are considered the best, but they are three to four times as expensive as pretty much everything else out there.
- I've run across nothing but good reports regarding axles from Raxles (www dot raxles dot com) in that they're roughly comparable with Honda axles at a fraction of the price.
Let us know how you make out.
96AccordEXV6
May 8, 2007 09:12 PM
