Drive axel vibration
Old Oct 1, 2012 | 04:25 PM
dward's Avatar
Thumbs down Drive axel vibration
I have a 1995 Accord - 4cyl, automatic with 110K on the clock. Recently I elected to have the drive axels replaced since the boots were rotted and I wanted to be proactive. Since I had the axels changed I notice a vibration in the drive train during right hand turns when the transmission upshifts from 1st. to second. The vibration is also noticeable while driving straight from a full stop, again when the transmission upshifts from 1st into second gear.
This is a new problem, the vibrations were not there until I changed to drive axels. My mechanic put in a second set to see if the first set was out of balance, the second set is at least as bad as the first. I might mention that the replacement axels are Chinese supplied by Cardone - could that be the problem?
Anyone else experience similar problems?
Old Oct 1, 2012 | 04:40 PM
shipo's Avatar
I've heard from numerous sources that Honda's can be very particular about their axles, and various truisms have been pressed upon me:
  1. New axles are better (as in less likely to cause wobbles and vibrations) than Remanufactured axles which are better than Rebuilt axles.
  2. Not all "new" axles are created equal. Autozone, Car Quest, Pep Boys, et al. seem to have a spotty reputation even with their highest quality (most expensive) axles; some folks have no issues, others have had to replace axles several times before the get the vibration issues solved.
  3. Honda axles are considered the best, but they are three to four times as expensive as pretty much everything else out there.
  4. I've run across nothing but good reports regarding axles from Raxles (www dot raxles dot com) in that they're roughly comparable with Honda axles at a fraction of the price.
I've yet to delve into any Honda axle issues so nothing I've written is from personal experience.
Let us know how you make out.
Old Oct 1, 2012 | 04:57 PM
dward's Avatar
Thanks for the information, I think I will put the old axles back in to see if the problem goes away.
Old Oct 2, 2012 | 12:17 PM
Nothing wrong with recommending someplace like that, but if it's not a sponsor we aren't supposed to use active links to selling-sites.
Old Oct 2, 2012 | 12:20 PM
shipo's Avatar
Oops! Sorry about that; won't happen again.
Old Oct 2, 2012 | 12:33 PM
I ran through 2 replacements of axles w/ AZ remans to fix a vibration under acceleration problem. I bought raxles and fixed the problem.
Old Oct 2, 2012 | 01:37 PM
shipo's Avatar
Another vote for Raxles.
pmatos
Apr 12, 2009 01:04 AM
96AccordEXV6
May 8, 2007 09:12 PM
mzungu
Apr 20, 2007 09:30 PM
chibiko
Apr 7, 2007 10:43 PM
onedollaraccord
Mar 30, 2007 03:52 AM
