Electric Problem
Old Feb 27, 2009 | 09:43 AM
Honda1611
Default Electric Problem
I have a 1998 accord, when this cold is a flaw in the engine. This bug seems to be electric. When the engine heats up the problem. It has changed the petrol pump, spark plugs and spark plug wires.
I need Helps.
Tengo un accord 1998, cuando esta frío tiene una falla en el motor. Este fallo parece ser eléctrico. Cuando el motor se calienta desaparece el problema. Se le ha cambiado: la bomba de la gasolina, las bujías y los cables de las bujías.
Thanks.
Old Feb 27, 2009 | 11:11 AM
Welcome new member!
Describe the problem a little better so we can help.
Old Feb 27, 2009 | 11:21 AM
finch13's Avatar
My Spanish is rusty, but he said something along the lines of:
"I have a 1998 Accord, when it's cold I have an error in the engine. This fault seems to be electric. When the motor is hot, there doesn't seem to be a problem. I have changed: the fuel pump, spark plugs, and wires."
Honda1611,
¿Su motor al ralentí áspero?
¿El motor de salto de 600 a 1200 rpms hasta que el motor está caliente?
Esto suena como obstruido EGR puertos. O bien, podría ser una sucia IACV o FITV válvula.
Old Feb 27, 2009 | 08:30 PM
Cool Please Type In English Only
And in the correct forums always...
Old Mar 2, 2009 | 08:35 AM
Finch, the 1998+ does not have a FITV.
Old Mar 2, 2009 | 09:39 AM
finch13's Avatar
Thanks for reminding me... I should've known better since I have the same car...
honker3
May 25, 2011 12:11 AM
flbob
Sep 15, 2010 03:31 PM
mcmadjock
Dec 3, 2007 02:43 AM
Billy J.
Nov 13, 2007 03:59 AM
tbopha
May 7, 2006 03:03 PM
