engine bumps at 4000 rpm
Old May 30, 2007 | 12:32 PM
saad180's Avatar
Default engine bumps at 4000 rpm
I have a 99 accord2.3 VTEC.
Wejust rebuilt the engine before this problem started.
Once the check engine light comes on , it doesnt want to go over 4000 rpm.
After we erase the code the car can go pass 4000 rpm immediately.
I had theenginescanned and they told me it said"Fuel air Metering "-1259
I can't figure it out, can some please help me .
Old May 30, 2007 | 02:13 PM
sir_nasty's Avatar
Default RE: engine bumps at 4000 rpm
From everything I've read it's either a vtech selenoid problem or perhaps a bad wire to your ECU (or improper ecu but I doubt that....) Here's a thread that's about the same issue, different car
http://www.vtec.net/forums/one-messa...sage_id=448713
Old May 30, 2007 | 05:34 PM
BlkCurrantKord's Avatar
Change the oil or add more. Should fix it right up. Wait for the oil pressure to build before trying to go to vtec.
Old May 30, 2007 | 07:52 PM
saad180's Avatar
I checked my oil and it was a little low. I filled it and hopefully that will do it.
thanks for the help.
Radfordicus
Feb 1, 2016 07:17 PM
Airhead
Jul 21, 2014 04:55 PM
Rilex
Sep 4, 2013 09:51 PM
james_nbdt
Feb 24, 2013 09:44 AM
maffuh
Jan 27, 2006 06:47 AM
