Front Crank Seal
Old Feb 1, 2012 | 04:02 PM
Cornfednbred's Avatar
Default Front Crank Seal
The front seal on my Honda is leaking pretty good, is it possible to change the seal bye going in through fenderwell? Or is it one of those things where it would be easier just to yank the motor out. I just dont know how bad it would be to mess with the timing belt in the car. The car is an 89 Accord with the 2.2 Auto Fuel Injected.
Thanks
Old Feb 5, 2012 | 09:27 AM
You can get to it with the motor in the car.....done it several times, latest adventure was in Sept 2011. I will also add that the o-rings on the oil pump can leak as well.....I'm assuming you pulled the upper cover and made sure it wasn't coming from the cam seal.....you can run the car with the upper cover off.
Old Feb 5, 2012 | 04:00 PM
No, I hadnt checked either of those. Thanks for giving me a couple of other things to look for. Thankfullly I think she can hold in there until the weather warms.
Frugalhondaguy
Aug 31, 2015 10:33 AM
momonola
Jun 25, 2013 04:57 PM
honDUHchick
Mar 8, 2013 06:53 PM
jdgoleman
Mar 2, 2008 07:05 AM
