fuel filter
Old Nov 14, 2007 | 10:48 PM
noboundaries6289's Avatar
Default fuel filter
hey all. I was interested in changing my fuel filter today to improve gas mileage. The service department clerk said that the filter rarely needs replacing. So I paid about $100 for a fuel system service. When should I change my fuel filter?
Old Nov 15, 2007 | 11:26 AM
sir_nasty's Avatar
Default RE: fuel filter
I'd probably do it every 90k or so. Not sure what the manual suggests for interval
Old Nov 15, 2007 | 01:23 PM
falkore24's Avatar
well ..... I guess that's another thing that I have to do!!!
Old Nov 15, 2007 | 01:29 PM
deserthonda's Avatar
i would strongly suggest to replace it every 60k miles
there is a write up on our DIY section on HOW TO REPLACE IT..
filter costs about 25 dollars, from dealer
Old Nov 15, 2007 | 02:25 PM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: falkore24
I don't think you have one. There is a built in filter "screen" on the fuel pump I believe. It is not supposed to need replacing that I know of. You could clean it I guess.
Old Nov 15, 2007 | 02:38 PM
falkore24's Avatar
next time I'm underneath, I'll look ...... I thought all had filters!!!!
Old Nov 15, 2007 | 05:34 PM
on your 00 car, the fuel filter is part of the fuel pump, inside the tank,
like 00 Accord said, it is a screen, and supposely lasts forever,
if fuel pressure drops , that would be one of the first things i would look at to see if it is plugged ..
Old Nov 16, 2007 | 08:31 AM
falkore24's Avatar
Yea!!! 1 less maintenance item!!!!! My car is running fine, so I'm not going to mess with it. It seems that my tranny is getting a little sloppier with the 1-2 shift when I'm flooring it ..... I "shift" around 6000 rpm's and it still hits the 7000 rpm limiter. I was ripping down the highway with a friend of my sister's and I bounced the 1-2 shift like 4 times ...... now he thinks his '94 MX6 w/ 240HP JDM motor is the same speed as G3. Not a bad run all considering ..... he has a 5 speed and 2 less doors.
rockhoundrob
Apr 11, 2014 11:41 AM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
mojorison_75
Dec 4, 2005 06:40 PM
Buckeye
May 8, 2005 12:41 AM
