fuel problems
Old Apr 1, 2013 | 11:20 PM
jjerred's Avatar
Default fuel problems
I just put a new fuel pump in and still no fire-up. Fuel is going through line up past fuel relay. No throttle control what so ever. Tps? Any ideas will be helpful thanks for ur much needed help
Old Apr 2, 2013 | 07:28 AM
What kind of car?
What do you mean "past fuel relay"? The fuel pump relay is under the dashboard...
Old Apr 3, 2013 | 03:22 PM
jjerred's Avatar
92 honda accord. N I mean I have fuel pressure all the way up to the injector rail. No spark to the plugs, crank no start. How do I test the distributor? I have been told its the tdc and crank position sensors or the coil in the distributor.
Old Apr 3, 2013 | 05:27 PM
Have you checked for any stored codes? On these you only need a paper clip and then count the flashes from the CEL light.
Do you have a volt meter? If so there are some tests that can be done to figure out what is wrong....ICM, coil, ect.
Old Apr 4, 2013 | 11:16 AM
jjerred's Avatar
I do have a volt meter. Thinking its the coil. How do I test it?
Old Apr 4, 2013 | 05:51 PM
Can't remember so I will just ask....does this have an internal or external coil?
External, easy to test for spark from it.
For testing, see this for some tests you can preform: Honda Acura ignition (no spark) troubleshooting tutorial - How to
Old Apr 6, 2013 | 12:35 AM
jjerred's Avatar
internal coil
BigOBob
Jan 1, 2012 02:47 PM
woody
Sep 15, 2010 09:20 AM
fortyfootelf
Jan 22, 2010 07:15 PM
kissbally78
Jan 18, 2009 07:14 PM
KimberlyC
Apr 16, 2006 11:51 AM
