how do you tell if you have a vtec?
Old Jul 6, 2008 | 12:51 PM
imactheknife
Default how do you tell if you have a vtec?
is there any place to check if your engine is a vtec? thanks Mark
Old Jul 6, 2008 | 12:52 PM
importedminds's Avatar
Default RE: how do you tell if you have a vtec?
should say vtec on the valve cover
Old Jul 6, 2008 | 12:58 PM
imactheknife
cool, guess thats a no then..oh well....thanks for the info...
Old Jul 6, 2008 | 02:12 PM
03Sleeper's Avatar
TURBO THAT ENGINE.
:P
Old Jul 6, 2008 | 02:18 PM
Also it would help if you put in your Year, make, model in the additional area of your profile like most of the other members do...
Without that information its like me asking if you carry a wallet in your glove box
Old Jul 6, 2008 | 03:12 PM
YeuEmMaiMai's Avatar
looking up your engine model will do the same (example F22B2)
Old Jul 6, 2008 | 06:52 PM
ford's Avatar
just as what the others said...put the year, model, trim, of your car and we can most often than not tell what your engine is..or just by looking under hood...check your engine..=D..if its dosnt say vtec on the cover then most likely its not..but sure way to check is by the engine name...ie: F22B2,etc..
Old Jul 6, 2008 | 08:28 PM
imactheknife
I have a 96 odyessy that I was selling and I thought it had a 2.3 litre in it for some reason so I thought that might be a Vtec...
Old Jul 7, 2008 | 01:23 AM
ford's Avatar
i've researched your car at wikipedia for you and it says there that the 96' Odyssey have the 2.2L I4. The 2.3L VTEC only came out on the 98' Odysseys...so im pretty sure yours is a 2.2L non-VTEC..
Old Jul 7, 2008 | 09:27 AM
The engine type &block serial number are stamped on a flat spot on the front, alongside the exhaust manifold, right at the split between the block & the tranny bellhousing.
First line is the engine type like F22B2 or whatever. Read it off YOUR engine then theres no guessing.
kc68
Jun 16, 2016 05:17 PM
sprah
Apr 26, 2012 09:39 PM
cg31998
Dec 15, 2010 10:29 AM
stephen94accord
May 19, 2009 04:56 PM
subby
Oct 23, 2006 09:58 PM
