just swapped, but no go
Old Aug 7, 2006 | 09:22 PM
LaminatedKitten's Avatar
Default RE: just swapped, but no go
got the fuel system etc to fire up, was a ground that was hiding behind all kinds of ****. now it just won't run, i fear its timing is crap, i'm gonna fix that as we speak, i'll keep y'all updated on whether or not The Duke is gonna be drivin tonight
Old Aug 7, 2006 | 09:36 PM
sir_nasty's Avatar
what's it do when you start it? does it run at all? If you have a timing light that's a good thing to check (like you're already doing....) let us know. Thanks for the updates
Old Aug 7, 2006 | 10:23 PM
how do i get the no1 to TDC? i can't seem to find any markings showing
Old Aug 7, 2006 | 11:15 PM
mbo1985's Avatar
take cyl number 1 spark plug off and put your hand over the spark plug hole. Have someone turn the motor by the crank bolt untill you feel compression.
Old Aug 10, 2006 | 01:30 PM
ok, i did a few things, got her running and driving. but now i've got another issue. unstable idle. it will surge from 1100-1800 and back, repeatedly to no end. sounds like a vacuum leak? no leaks. any ideas anyone?
Old Aug 10, 2006 | 03:00 PM
sir_nasty's Avatar
just to verify but you hear the engine surge or just the tach is showing it? If the engine is surging first thing I'm curious about is if you set the timing. If that's done then check for vacuum leaks, no leaks, clean the EGR valve/hoses, if that's clean try adjusting your idle screw....
Old Aug 10, 2006 | 07:42 PM
  #17
ORIGINAL: sir_nasty
actually is surging, you can hear it (considering exhaust is basically non existent). timing got set at a local shop, no vacuum leaks, i figured that out when a hose latched onto my finger and when a spray down of the area showed nothing, haven't done the EGR yet, but the idle screw is closed, shouldn't idle at all.
Old Aug 10, 2006 | 10:39 PM
  #18
update: damn near everything with a vacuum hose attached or attached to the upper manifold got either cleaned up or replaced, but it is still surging. could there be an ECU/electrical issue going on? it does it whether moving or not, if i ride 1st gear it will accel/decel just like idle.
Old Aug 11, 2006 | 02:39 PM
  #19
lightshow's Avatar
take the iac valve off the old motor and put it on your new one.
Old Aug 15, 2006 | 09:35 PM
  #20
i've swapped everything i could off of the old manifold onto the new one, still does the same thing? had someone say ECU but i had doubts. are there any other vacuum hoses on the bottom side of the intake manifold besides the ones that run to the black box?
alkemyst
Apr 10, 2013 10:42 AM
JP98
Jan 5, 2009 11:46 AM
Fibercation.com
Jul 10, 2008 10:38 PM
aboutblank29
Oct 19, 2007 12:15 PM
