Losing power
Old Aug 10, 2009 | 03:59 PM
Mikkos21's Avatar
Default Losing power
Hello guys,
I've noticed that my car is losing power during take offs, especially going up an incline. It's a 2001 Accord with 284,000 miles. I take care of vehicle and it runs quite well with 284,000 miles. What could be the problem?
Old Aug 10, 2009 | 07:46 PM
jasonfridlund's Avatar
1st option. transmission (especially an auto) manual transmissions have dif problems.
2nd option. gunk has built up in the engine and it needs a total service with an engine flush (about 65 bucks)
3rd option. pistons arent sealing properly and you are losing compression. Try asking a mechanic to look at your pistons, piston rings, and each cylinder for decompression type stuff.
4th option. the ecu is on the fritz and every time you lose a little traction the traction control system goes crazy like on a mercedes.
5th option. If you dont change your oil about every 3000 miles at your car's age, you can get a lot of scarring on the internals. get eneos, amsoil, or mobil 1 synthetic. This will smooth everything out and get you back on track.
these may be the problem. i cant know w/out looking right at your car and taking it apart. Hopefully this helps.
Old Aug 11, 2009 | 08:25 AM
Possible plugged EGR passageways?
watut
Sep 26, 2010 01:04 PM
larrypac99
Nov 11, 2009 01:44 PM
ditchdoc1017
Nov 2, 2009 09:21 AM
honda86
Mar 22, 2009 07:06 PM
evs
Mar 1, 2007 12:07 AM
