1990 honda accord losing power
Old Mar 17, 2009 | 04:45 PM
honda86's Avatar
Default 1990 honda accord losing power
im new to this so if you are confused this is my new thread im so confused on whats going on with this car so let me try and explain when i first got the car i drove it down the street and without stopping at a stop sign ,the speedometer stopped working and a green light what is suppose to be the sports option on the gear shifter went off and started flashing ,so right after all that started the car started to losing power ,but if you still drive it for a few mins the power will come back but not for long maybe a few seconds ,so now saying all that plz anyone im lost any suggestion ,i have been told that there could be a short somewhere , or the torque converter or the cadialic converter , or even a sensor , and a speed sensor , well thats all plz help me fix this car Thanks
Old Mar 17, 2009 | 05:29 PM
That was an impressive run-on sentence. Break up using punctuation so it is easier to read.
The S light means that the TCU detected a problem. Many problems can cause that to happen. Short the service connector and read the code. The connector is a two pin connector that is blue. Use a thin paperclip or a piece of wire to short the connector.
See: http://techauto.awardspace.com/trans...roubleshooting
Old Mar 18, 2009 | 02:21 AM
honda86's Avatar
Default thanks
thanks alot this might be the problem and i was in a hurry as i am now im not to sure about how to read the codes so if you could help me with that it will be a great help well thanks
Old Mar 22, 2009 | 07:06 PM
honda86's Avatar
Default New Problem
okay i fixed my car it seems to be running fine now.But now when im driving and gun it (I know it will eat the gas more)it eats the gas really bad. So my question is what might be causing that .I have changed the fuel filter. so what else could it be , im up for suggestions so thanks for reading .
fixitgirl29
Jun 8, 2015 11:32 AM
watut
Sep 26, 2010 01:04 PM
larrypac99
Nov 11, 2009 01:44 PM
Mikkos21
Aug 11, 2009 08:25 AM
evs
Mar 1, 2007 12:07 AM
