Mods for h22 accord
Old Aug 18, 2006 | 01:31 PM
Teddieb
Default Mods for h22 accord
I want to know any modifications that i could do other than intake, header, ehaust, and a turbo
Old Aug 18, 2006 | 08:46 PM
mbo1985's Avatar
Default RE: Mods for h22 accord
cams, internals (pistons, rods , valves, etc.), port & polish.
Decide if you want a Turbo or an N/A build and go from there. The paths are quite different.
Old Aug 18, 2006 | 10:57 PM
marbro's Avatar
specifically, cam gears, cam, valve rockers(usually around $1000+), valves, valve springs, titanium retainers, rods, pistons(low compression for turbo, high compression for n/a) if you goto forged pistons you have to sleeve your cylinders because if you dont you will eventually crack the existing FRM walls and have pretty much complete engine failure, FRM can handle only so much extra over stock oddly enough the upgrades you can do on most of the engine are exactly the same in terms of the upgrade
absolutalchemy
Aug 1, 2006 01:50 AM
newaccord99
Jul 3, 2006 07:46 AM
johnnie518
Jan 6, 2006 10:21 AM
htowngoalie32
Dec 6, 2005 02:10 AM
DrumProdigy83
May 3, 2005 12:28 PM
