Mods for h22 accord
specifically, cam gears, cam, valve rockers(usually around $1000+), valves, valve springs, titanium retainers, rods, pistons(low compression for turbo, high compression for n/a) if you goto forged pistons you have to sleeve your cylinders because if you dont you will eventually crack the existing FRM walls and have pretty much complete engine failure, FRM can handle only so much extra over stock oddly enough the upgrades you can do on most of the engine are exactly the same in terms of the upgrade
newaccord99
Jul 3, 2006 07:46 AM
DrumProdigy83
May 3, 2005 12:28 PM
