Oil change
Old Nov 29, 2013 | 06:36 PM
lesiza's Avatar
Default Oil change
I am planning to change my oil sooner,
I don't know what is the right kind of oil to use.
Others say use synthetic others say standard oil.
My car is a 1994 honda accord LX 4 doors sedan
Help!
Old Nov 30, 2013 | 07:00 AM
Kind of a debate, as you can tell by the different things you've been told already.
All I will say is use the proper weight oil (I believe 5w-30 for your car, double check me) with the correct API rating.
Old Dec 2, 2013 | 04:42 PM
Synthetic oil should allow you to go longer before changing oil. But getting your oil analyzed will tell you how much longer. And then, even if you don't count the $$ for oil analysis, the synthetic is more expensive so it might not save any money anyway.
Do you live in northern Canada where extreme low temperature will give the advantage to synthetic oil?
Old Dec 27, 2013 | 10:35 AM
amccinns's Avatar
I always use synthetic. Maybe overkill, but it can't hurt and might help.
Old Dec 27, 2013 | 10:43 AM
It's similar to buying premium gas when regular is design spec. It doesn't hurt anything but your wallet.
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
chris h
Apr 3, 2011 10:01 AM
ziwang55
Jun 6, 2008 01:25 PM
62maxx
Nov 21, 2006 12:04 PM
