oil leak
Old Feb 12, 2008 | 08:20 PM
jmcmichael08's Avatar
Default oil leak
there is oil being pushed out of the bottom of my distributor....should i replace the whole distributor or is there a seal that could stop the problem?
Old Feb 12, 2008 | 11:48 PM
Default RE: oil leak
What's the 'bottom'? If it's leaking INSIDE the body of the distributor, then you can't replace that seal. Need a new distributor body.
If it's leaking down the side of the head, from the OUTSIDE of the base of the distributor, it's easier. There's an O-ring on that end of the distributor.
Old Feb 16, 2008 | 08:36 PM
sorry about that...it was the o-ring on the distributor shaft. problem solved
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
