Oil smoke after headgasket replacement?
Old Jan 10, 2011 | 12:58 PM
meat27's Avatar
Default Oil smoke after headgasket replacement?
1990 Accord LX auto
I bought this car with no compression on one cylinder due to a burned exhaust valvle. Aside from the obvious skipping, the engine was running fine with NO smoke.
I removed the cylinder head, replaced the burned valve, installed a new head gasket and put it back together. The skip is gone, it runs fine, but it is smoking like a mosquito truck! It is definately oil smoke. Moreover it puzzles me that I can remove the plug wire from the cylinder that I brought back to life, and it still smokes like crazy.
I rechecked head bolt torque. I don't know how that much oil can be getting into the cylinders. Can anyone think of something that I'm overlooking?
Old Jan 10, 2011 | 05:19 PM
g22cd5's Avatar
Supper Moderator
are you sure you put the HG and the right way? It is very easy to put it on backwards.
Old Jan 11, 2011 | 09:17 AM
meat27's Avatar
Thanks for sharing that possibility. I'm gonna feel like a dummy if I did that, but at this point, I'm hoping that's what I find. I'm about to lift the head back up and take a look.
mishakol129
Oct 29, 2012 10:03 AM
jra8858
May 4, 2012 12:34 PM
kwc308
Sep 25, 2011 05:31 PM
Da Flash
Jul 31, 2011 08:21 AM
hiTmanG11
Aug 2, 2006 02:28 PM
