overheated 98 accord
First, fix the leak or replace the thermostat to fix the overheating. Replace coolant and start engine. If engine starts and runs OK, maybe you got lucky.
A missing engine or blowing steamy, white smoke are common signals of failed head gasket. Coolant in oil, or oil in coolant are other possible symptoms.
You can also perform a coolant system pressure test or chemcal test for exhaust fumes in cooling system.
LukeEckart
Mar 26, 2011 07:08 PM
