Overheating
Old Jun 1, 2010 | 02:47 PM
Dange's Avatar
Default Overheating
Hey honda guys my girlfriend has a 97 Honda accord with the 4cyl non vtec. It keeps boiling the water out of the overflow tank. I have already replaced the thermostat yesterday but it continues to do it. Any help would be greatly appreciated. Thanks!
Old Jun 1, 2010 | 03:51 PM
g22cd5's Avatar
Supper Moderator
Have you done a coolant flush? You might have some stuff clogged up. Is the temp gauge reading where is overheating or is coolant just boiling out?
Old Jun 1, 2010 | 06:26 PM
Dange's Avatar
No I havnt done a flush, but I have to put water in everyday. I cannot find any leaks, and it's boiling out quite a bit from the overflow tube. The guage reads fine until it has boiled the majority out.
Old Jun 1, 2010 | 06:40 PM
corvetteking's Avatar
Do a coolant flush... If that doesn't help, it could be a water pump issue...
Old Jun 1, 2010 | 06:46 PM
g22cd5's Avatar
Supper Moderator
Always do a coolant flush when you do a thermo job. ALWAYS
Dange's Avatar
Is there a write up on how to do a coolant flush?
Old Jun 1, 2010 | 07:31 PM
Next time just search the forum... I found this at the bottom of the page on the forum search for"coolant"
https://www.hondaaccordforum.com/for...hlight=coolant
Old Jun 4, 2010 | 04:50 PM
deserthonda's Avatar
chk the radiator cap..
Old Jun 6, 2010 | 12:53 PM
Gilo's Avatar
Smile
The same thing happened to me, i changed the thermostat and flushed the cooland at the end nothing worked. My problem was one of the fans was not working, check the fan if it does not start it may be the motor of the fan, u can buy it at any car store like auto zone or advance auto parts. Easy to install.
Old Jun 17, 2010 | 01:59 PM
Texas Tech's Avatar
My wifes 01 Honda accord had the same problem. After changing the radiator, thermostat, and flushing the coolant system several times it finally started smoking just a little at the tailpipe. Check and see if the tailpipe is blowing any white smoke at all. Hopefully not but if it is it has a blown head gasket. I've been a mechanic for over 15yrs and her car is the first i've seen that ran smooth and without any indication of a blown head gasket until 6 months after the coolant problem. Good luck and I hope this helps.
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
jordan
Sep 6, 2005 11:35 PM
Getsch
May 24, 2005 07:52 PM
