premium gas
Old Dec 3, 2007 | 03:08 PM
KevinAccord's Avatar
Default RE: premium gas
"Actually, higher octane gas produces less power with our cars. Higher octane means more resistance to ignition which means that it burns slower. Our cars have very conservative timing, so if you run higher octane than what's recommended, you are just spraying more unburned gas out of the engine to burn on the cat."
ummm ok, didn't knew that...(sorry steviebix)good to know, though my does needs premium since its turbo... right? there again, sorry, i did really thought it made a difference.
Old Dec 3, 2007 | 03:10 PM
00AccordLX5spd's Avatar
Registered User
Yeah you need to use premium if you are boosted.
Old Dec 3, 2007 | 03:11 PM
falkore24's Avatar
With a turbo, I'd run premium just to be safe ..... also, if you have E-Manage, you can advance the spark to actually take advantage of the longer burn time and make more power safely with the high octane gas.
Old Dec 3, 2007 | 03:12 PM
nafango2's Avatar
yea, you need to use premium.
Old Dec 3, 2007 | 03:23 PM
ok... that's where i've got my confusion, i thought it was the same w/ all cars... sorry once again.
Old Dec 3, 2007 | 05:26 PM
It's possible to tunea turbo with such mild spark timing & mild boost, that it takes regular. Most times that's not what happens whensomeone installs a turbo onto an F-series engine.
Old Dec 3, 2007 | 05:34 PM
  #17
falkore24's Avatar
True, possible, but I wouldn't try it until you've run calculations that show that the pressure isn't too high. The spark is already conservative unless it's been modified.
Old Dec 3, 2007 | 10:22 PM
  #18
Yeah, but the original post wasn't about boosted engines. So for normal people ;-), it's a waste of money.
Even with a knock sensor, the system will not constantly hunt for the point of incipient knocking. If it can use the programmed spark map without knocking, then it won't try to advance the timing any further.
Think of it this way...
If your engine control system isn't programmed to take advantage of premium gas, it's not going to help. That includes most Hondas.
Old Dec 4, 2007 | 10:27 AM
  #19
falkore24's Avatar
ORIGINAL: JimBlake
Agreed 1000000000000000000% ....... except ..... j/k
magiconthetire
Apr 24, 2023 01:02 PM
jasonfridlund
Jun 8, 2009 06:30 AM
dpmeersman
Jul 3, 2008 09:32 AM
newaccord99
Jul 18, 2006 08:27 AM
sexybeast06
Feb 17, 2006 12:43 PM
