Putting a vtec in my accord, it has 2.3 non vtec now
Old Jun 10, 2011 | 09:36 PM
Boogie's Avatar
Default Putting a vtec in my accord, it has 2.3 non vtec now
i have a 1998 accord with a 2.3 non vtec with a 5 speed, while i'm driving at 3k rpm i can hear a knocking noise but if i give just a small amount of gas it gose away or if i eazy off the gas it will also go away, however it sounds like it coming from the right side of the car, i thought maybe a rod or main bearing, but someone said it could be a wirst pin....who knows??? anyway i found a wreck 1998 accord with a SOHC vtec and i want to put it in my car, my problem is i have a 5 speed and it has a auto trans.....if i use the vtec motor what wiring and ecm do i use ? mine or the one from the wrecked accord being it's a auto and i want to keep my 5 speed, thanks you guys
Old Jun 11, 2011 | 07:52 AM
piggylover1985's Avatar
You might have to do complete the engine, wire harness and ECM. As for the motor from an automatic should be same as 5sp, take of the flex plate and bolt your old flywheel and clutch then you're good to go.
Old Jun 11, 2011 | 05:18 PM
g22cd5's Avatar
Supper Moderator
the engine is the same you can bolt your current 5speed f series trans to your new engine. Bolt patterns are the same. You don't need a cputer for a 5speed trans.YOU ARE THE COMPUTER
You will need to wire up vtec and vtec pressure switch here is a ling for ya...read bth links
http://hondaswap.com/general-tech-ar...re-vtec-40811/
http://www.hondacivicforum.com/forum...ad.php?t=73241
cd51994accord
Jan 30, 2014 12:56 PM
97hondaaccord
Jan 9, 2013 09:27 AM
blly8325
Mar 23, 2012 06:10 PM
stresser
Aug 17, 2010 08:04 AM
