shot 88 LX, donor 88 LXI, can I use injection?
Old Aug 23, 2010 | 10:09 PM
Jaymo's Avatar
Default shot 88 LX, donor 88 LXI, can I use injection?
My 88 accord LX has sticky rings at 249,000 miles, smokes like crazy at at cold startup (sometimes) I have an opportunity to get a low mileage injected accord LXI which was wrecked. What would I have to change in the wiring of the car? my current engine runs very strong but the carb has had fast idle problems when cold and stalls when hot. I'm sure the auto choke is worn out. anyway I would like to use the injection if it's possible. I suppose I could just continue to look for a carburated engine, any help would be appreciated. thank you.
Old Aug 23, 2010 | 11:45 PM
g22cd5's Avatar
Supper Moderator
I don't know much about the older accord but I know some of the carb engine accord did come with PGFI in the later years like 89 or so. I don’t see why it will be a prob. but I don't know your answer in full to be honest. Do some more research and I’m sure you will find your answer. Sorry I couldn’t help any farther than this...
Old Aug 25, 2010 | 08:17 PM
Jaymo's Avatar
any suggestions on where to research? it would be nice to just drop in the motor and the motor harness and just plug and play but I am afraid I may have to change allot of wiring I just wish I had some steering in the correct direction Honda's seem to be complex when it comes to the layout of just about everything, it wouldn't surprise me if the entire harness had to be changed (scary) thanks for any input.
Jay
Old Aug 26, 2010 | 04:23 AM
g22cd5's Avatar
Supper Moderator
Sometimes yes you have to do some wiring. I also have seen ppl drop b16 engines from civic si into the older accords. Much Much more power then what is in your car now or any engine from that point in time
maybe you can look into that. Look around on google for some older accord forums too. I'm sure they are out there just need to be found.
LokRobster
Dec 4, 2012 03:32 PM
Honda Enthusiast
Mar 9, 2011 09:22 PM
dksix
Jul 5, 2008 02:55 AM
Jeff247
Feb 6, 2006 09:00 PM
nrangerfan
May 19, 2005 12:56 PM
