Speedometer
Old Sep 17, 2009 | 06:06 PM
4dooraccordex's Avatar
Question Speedometer
my speedometer doesnt work, it floats, and sometimes will work, i was told it was because my tires were the wrong size, but that wouldnt even effect it. (plus the tires are the right size), and i was told there was a plug in the transmission that might be loose, and it could be effecting it. it baffles me.
i drive a 1994 accord ex
A/T
F22B1
Please Help
Old Sep 21, 2009 | 08:48 AM
Vehicle Speed Sensor (VSS) is located on top of the tranny, in back above axle line. Kinda below the throttle body.
That thing provides the signal to the speedometer. Look for loose/dirty/corroded wiring plugs. It's possible the sensor is getting flaky. Normally that would produce a check-engine light... ?
Old Sep 28, 2009 | 11:44 PM
h22a96_Accord
Yes I had the same problem in my 96 accord. It ended up being a bad sensor, but no CEL went off.
cochre
May 10, 2012 11:58 AM
UnitedAuto
Apr 18, 2011 10:44 PM
darryltravis
Apr 25, 2006 01:26 AM
cclc31
Oct 25, 2005 09:27 PM
cbriley3
Oct 23, 2005 11:04 PM
