Timing Belt
Old Feb 14, 2008 | 11:08 PM
playaman's Avatar
Default Timing Belt
Hey guys, I just wanted to visually check the condition of my timing belt. I got a 90ex with 230K k/m's. What can I do to check that out, there are no replacment stickers. Also when does the fuel pump usually go out? Should I replace that and the filter at this milage?
Oh and here's my Baby...
Old Feb 14, 2008 | 11:11 PM
playaman's Avatar
Default RE: Timing Belt
There she is...
[IMG]local://upfiles/8480/1FDBF45C1C0448E5852688FAD9EBF68B.jpg[/IMG]
Old Feb 15, 2008 | 07:31 AM
Determining the age of a timing belt by inspecting it is pretty sketchy. The ones I had ('95 GSR & '98 Accord) looked pretty good even when I changed them.
Old Feb 15, 2008 | 08:18 AM
playaman's Avatar
Not what I wanted to hear, considering the thousands I already spend...
Old Feb 15, 2008 | 11:40 AM
Sorry... If you want to try inspecting it, look at the inside of the belt, where it's teeth are. Checkfor tiny hairline cracks at the base of each tooth.
I'm just not very confident that those cracks will show upearly enough to make inspection worthwhile. Do you want to inspect it every week or 2?
What do you know about the history of the car? Obviously if you had a receipt for a timing-belt job you wouldn't be asking this question... If the belt was changed at a dealer, then maybe any other dealer can look it up by VIN? If it was done at a non-dealer shop or done at someone's home, then ????
Old Feb 15, 2008 | 06:56 PM
playaman's Avatar
K thanks for the good info, I'll have a look once it warms up outside. I will also check with a dealer.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
