timing belt
Old Nov 29, 2008 | 12:14 PM
srpowersuw's Avatar
Default timing belt
My car has about 74K miles. When does the timing belt need to be changed? How much does that usually cost?
Old Nov 29, 2008 | 12:24 PM
Default RE: timing belt
You may want to look into if your car has a chain or a belt, I know the 03 4cyl has a chain, which a chain needs to be replaced far less often.
I forgot when Honda recommends the belt to be done, its somewhere between 80-100k.
Old Nov 29, 2008 | 12:30 PM
botang47's Avatar
honda told me to do it at 100k but i didnt do it till 120k and it was working fine still. i just did it cause i was already changing my rotors, pads, water pump, and spark plugs already.
Old Nov 29, 2008 | 07:44 PM
skatingclaybird's Avatar
it cost me the whole timing belt and water pump tune up about 100 dollars
Old Dec 1, 2008 | 09:41 AM
falkore24's Avatar
SRSpower: I-m not 100%, but I think the interval is 105,000 miles on the timing belt. Unless you are doing the work yourself or with friends that are helping you for free, this job will cost between 500-800 dollars.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
