timing belt
Old Mar 1, 2007 | 06:46 PM
Honda_Dude's Avatar
Default timing belt
where is the timing belt on an 1998 Honda Accord V6? How often should I change it?
Old Mar 1, 2007 | 07:58 PM
HondaRacer4Vtec's Avatar
Default RE: timing belt
i belaive its on the left side of the motor or passager side which ever you pefrer. Anyway i heard the v6 ones last longer but still every 100,000 is always a good idea.
Old Mar 2, 2007 | 12:35 AM
Honda_Dude's Avatar
is the timing belt visible from just look at the engine? and how often must I change my tranny fluid and spark plugs?? and one more, wats the cheapest, best and easist way to clean the AEM Dryflow filter?? thanks
Old Mar 2, 2007 | 11:25 AM
RTexasF's Avatar
Super Member
The timing belt is not visible and is not a do it yourself item for most folks. I don't know what the book says but I would change the tranny fluid every 25K-30K miles or more often if it starts to shift roughly. Plugs, I don't know on that model hopefully someone else does. The only approved method of cleaning the AEM dryflow is with their own product. Google it, buy it, use it.
Old Mar 2, 2007 | 03:50 PM
Kyle's Avatar
if you get timing belt replaced you will probably have the water pump replaced. They are both usually replaced at the same time
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
