Tranny/Horn Problem
Old Dec 21, 2007 | 09:35 PM
eric123's Avatar
Default Tranny/Horn Problem
I'm having trouble with my tranny, wondering if anyone knew what it was. Its hard to shift into any gear. The clutch engages when I barely even move my foot, so this is the reason its hard to shift into gears. It happens when stopped or driving, the clutch doesnt release enough. What would cause this and how can I fix this.On a side note, my horn won't work either? I don't think its in the steering wheel, its got two horns, so I can't see both being gone but will still check, does it have a relay and where is it? All the fuses are fine. Appreciate your help.
1991 Accord
393,000 KM.
Old Dec 22, 2007 | 10:29 AM
sir_nasty's Avatar
Default RE: Tranny/Horn Problem
The tranny sounds like your clutch pedal is out of adjustment. Go to the website below and download your manual and it should have the procedure for adjusting your clutch.
http://www.hondahookup.com/manuals/
Old Dec 23, 2007 | 12:28 AM
eric123's Avatar
With 400,000 km's on the tranny, should I change the fluid. Or will it last till the tranny dies? 5 speed by the way, thanks
Old Dec 23, 2007 | 02:28 AM
19Accord97
Has the fluid ever been changed?!?!
Old Dec 23, 2007 | 12:19 PM
eric123's Avatar
Haven't owned the car the entire time, I have every record for it and don't have one for a tranny flush.
mvickky
Dec 21, 2007 11:04 AM
faosh
Nov 13, 2007 04:26 PM
foulmouthedleon
Nov 11, 2007 06:49 PM
Jaeger
Oct 19, 2007 12:48 PM
chronchameleon
May 12, 2006 12:47 PM
