Tranny Stuck!
Old Nov 21, 2007 | 04:19 PM
SteveO_f22a's Avatar
Default Tranny Stuck!
So i went to the store to get a pack of smokes, and when i got back i parked it in the driveway. i sat down and typed around on this website like i always do, and my dad came home early. so i decided to move my car since i parked in his spot. wierd thing is, now i cant get it out of park... WTF! ive read around and saw some stuff bout shifter solenoids and trannys that were no good any more. does any one have any ideas as to what might be wrong? and how do i check the solenoid to see if infact it is the problem? any advice is better than no advice. thanks..
Old Nov 21, 2007 | 04:24 PM
falkore24's Avatar
Default RE: Tranny Stuck!
hit the horn. post if it works. if not, find the bad fuse.
Old Nov 21, 2007 | 04:29 PM
horn works but more bad news...
i decided to stick the key in the shift lock release and put it in neutral to start it. reverse works fine. no problems rolling out out the drive way...
but when i shifted into d4 it took off in third gear. i parked it and shifted into "P" and it made a wierd sound. almost sounded like something under the hood dropped...
Old Nov 22, 2007 | 03:03 AM
doanutboi's Avatar
have you check your tranny fluid??
no fluid = seized tranny
Old Nov 22, 2007 | 03:16 PM
i know i need to change it. but i gotta wait for my dad to take his truck out of the garage. where is the drain plug on a 92 accord EX?
Old Nov 26, 2007 | 12:17 PM
nafango2's Avatar
as far as not being able to shift out of park, it is most likely your brake switch. go under the steering column and look at the cylender by the brake. turn the car to "ON" and jump the connecters on the cylinder. if you hear a clicking by the shifter you need a new brake switch. Also go to the DIY section under "cannot get out of park.. diagnose". Why do you need the drain plug? doesnt it have a dipstick? look past the upper radiator hose for a yellow dipstick. (really short). and check the level.
Old Nov 26, 2007 | 02:44 PM
sir_nasty's Avatar
have someone stand behind the car, turn the key to the on position, press the brake pedal, if your brake lights come on the switch should be fine, if the brake lights don't come on then most likely you have a bad brake switch.
Old Nov 27, 2007 | 12:05 AM
ORIGINAL: nafango2
im gonna have to change the fluid. i need to drain it
bigtex
Feb 21, 2018 11:08 AM
Clevor
Mar 26, 2014 01:31 PM
tranwreck
Apr 30, 2009 09:27 AM
jayallen40
Apr 27, 2007 09:00 PM
