tranny swap
Old Aug 5, 2012 | 12:17 AM
MYOWNACCORD1993's Avatar
Default tranny swap
Hi there, im brand new to this so bear with me. I just bought a 1993 accord lx two days ago,the synchos in 2nd are toast and reverse makes alot of noise so today i picked up another tranny from a 1990 lx with 140k off craigslist,(honda parts arnt super easy to get where i live)
So my questions are am i going to have a issue with the year differance? My car and the car i got the tranny from are both F22A1s,everything ive found says i should be fine. Aslo any tips at all about doing the transmission would be greatly appreciated!!! I aslo plan on doing a clutch preferibly an aftermarket one so some good brands would help too,thanks!!!
Old Aug 5, 2012 | 05:54 AM
The trans will fit fine.
Don't know what your long term goals are for the car? This make the clutch and flywheel question hard to answer?
Old Aug 5, 2012 | 11:19 AM
g22cd5's Avatar
Supper Moderator
any f series (excluding the f20c and f22c-s2k trans) and H sereies trans will bolt right yo to your block.
Old Aug 5, 2012 | 03:13 PM
Its a DD,it has a has a nice cold air intake and catback exhaust already,and i just got a obx header for it that ill put on when i do the transmission, other then that its gonna be stock,i was thinking a stage two clutch but might just go with a stage one,not sure yet.
Is it easier to pull the engine and tranny or just the tranny?? Was also thinking about doing motor mounts aswell
Old Aug 5, 2012 | 03:16 PM
aslo poorman212,my brother had a 88 lxi auto,had 250k and was running strong when he sold it,good cars!
Old Aug 5, 2012 | 06:23 PM
g22cd5's Avatar
Supper Moderator
don't run any clutch that is not rated for the power your making. a OEM clutch will be the best bet as stiffer clutch will cause you to have to rev higher to enguage the clutch.
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
dannnnnn
Oct 4, 2006 06:37 PM
02SE_VTEC
Oct 11, 2005 05:53 PM
