Tranny Trouble...Please help!
Old Nov 13, 2007 | 09:55 PM
gonecrazybacksoon
Default Tranny Trouble...Please help!
[/align]Ok guys here goes,
I have a 1994 Honda Accord LX with an automatic tranny. This afternoon while driving down the turnpike at about 70+mph, my car suddenly began to act as if it was in neutral (only it was still in drive). My car started to decelerate and my rpm's climbed as i pushed down on the gas pedal...so, I pulled over, restarted the car and everything appeared to be fine (the car accelerated like normal and ran normally). However, after work tonight, I went to drive the car again, and it did the same thing...now the speedometer is reading 0 and i cant seem to get the car out of first gear while driving...Does this sound mechanical or computer/electrical? Any ideas/help would be appreciated! Thanks!
Old Nov 14, 2007 | 09:50 AM
falkore24's Avatar
Default RE: Tranny Trouble...Please help!
It sounds like it's in limp home mode and should have a CEL. Search DIY for hoe to pull the code and post it here.
Old Dec 3, 2007 | 01:47 PM
vtectuner95
sounds like exactly what I went through a few times. If it starts getting worse/more frequent you'll need to rebuild that tranny or swap for a new one. I've found out that Honda a/t's arent the best if you drive hard at all, im in the process of looking to swap
Old Dec 3, 2007 | 02:35 PM
klrspz's Avatar
Please keep us informed.. I'm reaching 70k mi and wanna make sure I don't run into this problem (although I hear the 7th gen trannies are better than previous)...
I'm looking to do a tranny fluid change and add a Hayden 403 in ~7-8 mo, at which time i should break ~80-85k
[EDIT]
Can you guys include your mileage, as well as costs that you might have found?
I'd assume to go through the dealer for the tranny parts, anyone have other suggestions?
maro
Jun 4, 2009 08:35 AM
traided
May 26, 2009 10:51 AM
love
Sep 15, 2008 09:34 AM
jbone
May 12, 2008 06:54 PM
Brendo613
Feb 23, 2006 07:26 PM
