transmission rebuild
Old Nov 1, 2015 | 04:39 PM
desiredkarma's Avatar
Default transmission rebuild
my 2002 accord got the transmission rebuilt back in august 2015, due to hard shift/jerk. Im just curious what is a transmission rebuild suppose to include? I was told all the internal parts would be swapped. Are the pressure switches or solenoids included under the rebuild? I am asking because i have the check engine light p1738 second clutch pressure switch. The mechanic told me that the warranty is not covered for the second clutch pressure switch. So i have to pay to fix this. Just to point out after the rebuild i have no problems. Just this check engine light. Also with this light i do not notice any thing different of the way the car drives.
Old Nov 3, 2015 | 07:40 AM
Usually they will not replace the solenoids or switches when the trans is rebuilt.
You might check it and be sure the connector didn't come loose from the switch ?
Aggie07
May 17, 2011 08:35 AM
Murthy
Jan 6, 2011 04:55 PM
jeffk14
Dec 2, 2010 03:08 PM
AccordCroz
Sep 15, 2010 03:08 PM
Et5291
Dec 24, 2009 11:06 PM
