Vtec head
Old 09-05-2007, 07:18 PM
BuntinBoy9's Avatar
Default Vtec head
hey i own a 94 accord with a f22b2 sohc engine. I was wondering if there was anyway i could drop a vtec f22 series head or "top" on it and make it a vtec if possible. also i was wondering if you could do the same with a f23 head and drop it on there... i dont know. also what would it take to put this all together if it can and estimate cost. if you have any information that would be awsome
Old 09-06-2007, 07:35 AM
BlkCurrantKord's Avatar
Default RE: Vtec head
Find an F22B1 head, intake manifold, header, distributor, new headgasket and head studs and swap it on. Will probably require a new ECU and some wiring changes.
Old 09-06-2007, 09:41 AM
00AccordLX5spd's Avatar
Registered User
Also, if you can't do the work yourself, you're wasting your money IMO. Only 15 extra hp...maybe.
Old 09-06-2007, 01:50 PM
BuntinBoy9's Avatar
ya thats what i thought 00accord but i only plan on doing this when i get a different car to drive so the accord can be a project. also is a vtec better to turbo than a non-vtec?????
Old 09-06-2007, 01:51 PM
BuntinBoy9's Avatar
o yeah thanks for the info currantkord
Old 09-06-2007, 04:51 PM
Registered User
I really don't know the answer there.[sm=imsorry.gif]
I'm no turbo expert.
Project build would be ideal. Save you loads of money to piece together a turbo system than to buy a kit[sm=proof.gif]
Old 09-06-2007, 09:24 PM
BuntinBoy9's Avatar
now that you said that what all would i need to get to build my self a good working turbo system????
Old 09-07-2007, 01:00 AM
KevinAccord's Avatar
i know that! V-tech does a few things, but when going turbo, most cars disconnect the V-tech cause it takes extra oil to the camshaft so i works better. This desviation of oil causes the oil pressure to drop, and this means that the turbine gets lower pressure. that's part of the reason most ppl disconnect it. also the vtech gives extra gas at higher rpms, but the apexi does that when the car is turbo so it doesn't matter...
82009_honda
11-26-2009 09:17 AM
rtmobile96
09-27-2007 03:30 AM
dodins
03-18-2007 08:10 PM
94coupeaccord
12-10-2006 04:11 AM
poser_pilot6
11-23-2006 10:36 PM
Quick Reply: Vtec head
