VTEC swap vs. new valves
Old Jul 19, 2007 | 08:20 PM
white95's Avatar
Default VTEC swap vs. new valves
I'm told I have at least one bent valve. I was wondering if anyone whohad valves replaced could give me an idea how much it would cost if I am taking the head to a machine shop.
I'm also considering swapping in a VTEC instead, is there anyone who did this? If I understand correctly, it's pretty much: bolt on the head, replace ECU, add two wires for solenoid, use longer EX timing belt,and replace 1 or 2 vacuum lines. Am I close?
Also need to consider that I was hoping to sell it within the next year to get an EX. Would a VTEC swap hurt or help the resale value?
95 f22b2 accord 180k miles.
What would you do?
Old Jul 19, 2007 | 08:45 PM
stevent's Avatar
Default RE: VTEC swap vs. new valves
i think with any kind of swap, the value of the car decreases.
Old Jul 19, 2007 | 10:11 PM
BlkCurrantKord's Avatar
I doubt anyone would even notice if you did it should you ever resell the car or trade it in. Swap heads. Make sure you use ARP head studs
Old Jul 20, 2007 | 08:52 AM
white95's Avatar
I just spoke to a machine shop and they said it would be at least $250. They would have to completely disassemble the head even for one valve. So I'm really leaning towards the VTEC swap.
If I get the wiring harness from a f22b1 with the head and ECU, would I still have anything else to worry about?
Old Jul 20, 2007 | 03:23 PM
I dont think so, that should all pretty much take care of it.
Old Jul 20, 2007 | 11:12 PM
white95's Avatar
I'm looking at some stuff on ebay, I found an ecu from a 95 ex but it says it's for an automatic transmission. I was under the impression that the ecu had nothing to do with the transmission, at least on this gen accord.
I'm thinking I could actually piece this together, as in get the head and run it without hooking up the VTEC. Then I could come back to it later with the ecu etc... Sound right?
Old Jul 22, 2007 | 01:54 PM
white95's Avatar
I got the head off and it's worse than I thought, every piston has valve impressions on them. Should I just go with engine replacement at this point?Would the pistons be ok or would this affect the compression?
cd51994accord
Jan 30, 2014 12:56 PM
kshellz
Oct 24, 2012 10:51 AM
cg31998
Dec 15, 2010 10:29 AM
PTVDesign
Oct 28, 2008 09:20 PM
blackex19
Jan 14, 2007 02:01 PM
