will a stroker kit worsen my gas mileage?
Old Jul 18, 2007 | 07:45 PM
thunder_x's Avatar
Default will a stroker kit worsen my gas mileage?
Old Jul 18, 2007 | 08:03 PM
tkundert2's Avatar
Default RE: will a stroker kit worsen my gas mileage?
If you increase the displacement of your engine (via longer stroke) it will take in more fuel and air, so would very likely use more fuel per mile.
Old Jul 18, 2007 | 11:13 PM
It's not so much the stroker kit that does it. It's what you do with your right foot after it's installed. That's what uses more gas.
Old Jul 18, 2007 | 11:28 PM
thunder_x's Avatar
well, how about under normal driving conditions?
Old Jul 19, 2007 | 12:12 AM
It still takes the same amount of power to push the car down the road. So you'll usea little bit less throttle to drive the same speed. That's not perfect compensation, so you'll use a LITTLE more gas. But not as much as you'd expect by the proportion of displacement increase.
But'normal' driving includes plenty ofopportunity to accelerate... You won't hold back just because your car used to be less powerful. You probably aren't gonna go to the work of a stroker kit & then install a restrictor plate to put you back to the same horsepower.
Old Jul 20, 2007 | 10:18 AM
bssmagik83's Avatar
Almost A Senior Member
Run the pi$$ out of it!
Old Jul 20, 2007 | 10:27 AM
00AccordLX5spd's Avatar
Registered User
I didn't even realize you could get a stroker kit for our engines. Or are you talking about a custom job?
Old Jul 20, 2007 | 02:48 PM
marbro's Avatar
to my knowledge only h22's have a stroker kit
Old Jul 20, 2007 | 03:22 PM
BlkCurrantKord's Avatar
He has a 91 accord, he can use the H23 crank/rods or 98 and older H22 crank with the 50mm main journals.
yroctrah
Mar 16, 2012 04:48 PM
westcoast_accord
Aug 10, 2011 07:05 PM
DA KID RYU
May 14, 2008 09:57 AM
Zambo
Jun 23, 2006 04:16 AM
