will a stroker kit worsen my gas mileage?
It still takes the same amount of power to push the car down the road. So you'll usea little bit less throttle to drive the same speed. That's not perfect compensation, so you'll use a LITTLE more gas. But not as much as you'd expect by the proportion of displacement increase.
But'normal' driving includes plenty ofopportunity to accelerate... You won't hold back just because your car used to be less powerful. You probably aren't gonna go to the work of a stroker kit & then install a restrictor plate to put you back to the same horsepower.
