01' Accord EX Code P1831, CYP SENSOR, changed distributor, same code came back
Old Jan 25, 2011 | 07:55 AM
  #21
One bad diode in the rectifier bridge will cause a couple things...
- reduced charging capacity = lights dim when operating too many things together
- rough, noisy (not smooth) generation of electricity = interference with electronics
Sounds like a bad diode in the rectifier continues to be a good suspect. Find someplace that can properly test the alternator under load.
Old Jan 25, 2011 | 01:52 PM
  #22
Rtherres's Avatar
Ok so i called one of our better local mechanic shops and asked about testing the alt. They said they would run the same test that kragens does for free so i might as well take it there.
Is a kragens test gonna tell me enough or no? I mean the alt still charges the battery. I thought the kragens test really just tells u its fine or no its totally shot. Anyone?
Old Jan 25, 2011 | 06:57 PM
  #23
Auto parts stores should be able to tell if the alternator is capable of putting full amperage and whether it may have a failed rectifier or weak brushes.
Old Jan 25, 2011 | 08:41 PM
  #24
If you're lucky, Kragens uses a scope to look at the wave-form coming out of the alternator. Even if not a scope, they'll actually measure the amperage, not just "turn on all the lights & motors".
So it's a free test. You already got enough reason to suspect that it MIGHT be the alternator.
Old Jan 25, 2011 | 08:43 PM
  #25
Originally Posted by Rtherres
Ok so i called one of our better local mechanic shops and asked about testing the alt. They said they would run the same test that kragens does for free so i might as well take it there...
Sounds like they're being honest & not just taking your money for something that you can get for free.
Old Jan 26, 2011 | 12:48 AM
  #26
Rtherres's Avatar
Alright thanks u guys. Ill be takin the alt out and to kragens this sat. Ill make sure i come back and post the findings.
Old Jan 26, 2011 | 08:36 AM
  #27
Gotta take it out or can they test it in the car? (Phone call to Kragens?)
Old Jan 30, 2011 | 04:58 PM
  #28
Rtherres's Avatar
Well i think its fixed. Took the alt out of the car and had kragens test it for me. It failed. Apparently it was over charging which was a new one for me. He showed me the amperage specs and it was over by a little bit but i guess it was enough. The odd sound that was comin from the engine is gone too. Thanks again to everyone for the help.
Frankenstein94
Dec 10, 2014 01:04 PM
4flroses
May 26, 2014 07:46 AM
93Accord2.2
Nov 6, 2013 11:53 PM
Weebiecat
Sep 5, 2013 11:54 AM
hondac27
Apr 27, 2012 09:28 PM
