01 Accord EX - Inner Tire Wear
Old Jun 19, 2016 | 04:04 PM
ctgriffi's Avatar
Default 01 Accord EX - Inner Tire Wear
Got a rotation and balance done on my wife's 01 Accord today, and they mentioned that I was getting a lot of wear on the inside of one of the rears. (This car has 153K, and just 30K on its current set of tires: Hankook Optimo H727.)
I'm a careful, handy guy with some good tools (who can do some math), so I did a camber check in my garage when I got home. Obviously, these are not perfectly accurate numbers, but I think I got pretty close with them:
Front Driver: 0º
Front Passenger: -0.54º
Rear Driver: -1.1º
Rear Passenger: -1.5º
Questions:
  1. What do these numbers tell you if, for the sake of discussion, we can agree they're mosty accurate?
  2. What can I do about the situation, DIY-speaking, in the event that repair is needed?
I also put the car up on jacks and inspected front and rear suspension parts for unusual abuse, bent metal, and/or looseness. Tugged on each wheel at 12-and-6, as well as 3-and-9 but couldn't detect anything amiss there either.
Many thanks!
Last edited by ctgriffi; Jun 19, 2016 at 04:05 PM. Reason: corrected a measurement
Old Oct 23, 2016 | 09:07 PM
ctgriffi's Avatar
Hey, just checking in again, to see if any experienced people have some advice about this inner tire wear situation (see above)... what typically causes this? What kind of adjustment could be made? Appreciate the help.
Old Oct 23, 2016 | 10:12 PM
I'll have to look up the camber spec on the 01 and post it in a bit.
I think the only adjustment on the rear of the vehicle is toe. The car may need an alignment. There are also some youtube videos on how to measure toe and do an alignment.
Old Oct 24, 2016 | 03:20 PM
The Toecutter's Avatar
Yup, that was my thought too. If your numbers are good, then that's really not enough to cause wear. Does the car pull either right or left? How about in either the right or left lanes of the freeway? Just asking, as the more info we have the better advice we can give.
Old Oct 25, 2016 | 11:52 AM
ctgriffi's Avatar
So, at further research, I'm pretty sure the numbers are pretty bad—for camber OR toe. Spent an hour doing some careful measuring again with plumb lines, level, calipers, etc. Here's what I found:
CAMBER
Front Driver: -.02º (Desired range: -1.0 to +1.0º) OKAY
Front Passenger: -.55º (Desired range: -1.0 to +1.0º) OKAY
Rear Driver: -1.2º (Desired range: -1.0 to 0º) TOO MUCH
Rear Passenger: -1.6º (Desired range: -1.0 to 0º) TOO MUCH
TOE
Front Driver: -.22º (Desired range: -.08 to +.08º) TOO MUCH
Front Passenger: -.18º (Desired range: -.08 to +.08º) TOO MUCH
Rear Driver: -.34º (Desired range: 0 to +.16º) TOO MUCH
Rear Passenger: -.15º (Desired range: 0 to +.16º TOO MUCH
Anyway, I talked to a local tire/alignment shop with a good reputation, and they're gonna take a look at everything tomorrow. They're familiar with these vehicles, know how to make camber adjustments if needed, etc. And, they walk you through everything they're doing, which is right up my alley.
Old Jun 7, 2017 | 07:46 AM
DaPenguin's Avatar
Hello all. I'm new so bare with me. My ride is having the same issue. both rear tires have inner uneven tire wear. Lots of thumping as I drive. Car doesn't pull in any direction regardless of speed. bought the car new and has 32k miles. the issue began at the same time on both tires and become really obvious once the tires starting thumping. I've been hearing that it is a common issue with the accord.. please help..
btw i have no clue if its a toe or camber, I haven't been able to find any diagram on the 2015 accord.
I ordered new tires but I need to fix this issue before my new tires suffer the same fate...
thanks.
Old Jun 7, 2017 | 08:14 AM
shipo's Avatar
thanks.
Have your dealership or tire shop do a 4-Wheel alignment.
Old Jun 7, 2017 | 12:03 PM
... and ask for the before & after numbers.
Old Jun 8, 2017 | 07:11 AM
DaPenguin's Avatar
Still learning lingo on car stuff. What my both rear tires have is cupping on the inside. Car is at 25k miles.
Girlie-Girll
Sep 18, 2012 02:58 PM
John R
Aug 6, 2010 07:46 AM
fireballer44
Jul 25, 2006 03:22 AM
elvis
Jul 11, 2006 06:03 PM
