01 Accord Power Steering Problem
Old Mar 10, 2021 | 10:48 AM
Seanjordan20's Avatar
Originally Posted by JimBlake
To me, a squealing noise sounds like a slipping belt. Can you have someone start the engine while you watch to confirm the PS pump pulley is turning properly? Then do the first couple turns in an empty parking lot somewhere, then confirm that the squealing sound is actually coming from the drive belt?
I'm with you on the squealing noise.
Old Mar 10, 2021 | 05:14 PM
I also should have said...
Belts can get hard & slippery with age, even though they look fine. If you're real lucky, you might simply need a new belt.
Old Mar 10, 2021 | 11:41 PM
MichaelQ's Avatar
on a few occasions, I’ve felt what seems like a jerking motion in the steering wheel. Not often but a couple of times for sure.
Old Mar 11, 2021 | 07:23 PM
We have to rule out the simple stuff first. Can you verify the pump pulley is spinning properly when you first start up? I'd hate to suggest you replace the pump & then find out it was something as easy a loose or bad belt.
cadillacmike
May 12, 2013 10:56 AM
supercd5accord
May 15, 2011 09:33 AM
inthedump
Nov 30, 2009 07:30 AM
mrscotty
Dec 11, 2007 08:00 PM
ohccord
Nov 13, 2006 12:15 PM
