02 Accord EX 4cyl upshift durning coasting
Old Mar 21, 2015 | 10:47 AM
02EX's Avatar
Default 02 Accord EX 4cyl upshift durning coasting
New member here. Got my 02 Accord ex 4cyl a couple of years ago from salvage bc of a head gasket blown on the previous eng. when i got this car it had about 160k drove nice even before the head gasket let go. now with 186k on it and driving it for awhile after it sat for a couple of months while the car was inop, i've been experiencing some noticeable upshifts while coasting downhill before a stoplight and at idle there is a noticeable grinding noise around the bellhousing area. Would this be more of a torque converter issue or would some of these symptoms be more of wear and tear on the transmission, i do alot of in town driving, but have taken this out on the road a few times. 100-200 mile round trips. Any suggestions? I've ran across some threads about checking the solenoids but havent ever done this procedure. Any help is better than nothing, and i know that trying to diagnose a car over the internet isn't the ideal thing to do, just trying not to spend thousands of dollars.
Old Mar 21, 2015 | 12:35 PM
I would check for codes. Most parts stores will read codes for you.
Check the transmission fluid level. When was the last time you changed the fluid?
You can do a resistance test on each solenoid. There are two wires to each solenoid on the 02, so test the resistance across the pins. It should be 12-25 ohms. You can unbolt the solenoid and check for debris in the screen and the solenoid.
Old Mar 21, 2015 | 12:41 PM
While coasting downhill, it may be due to Honda's grade logic.
It may be downshifting for added engine braking when needed; instead of upshifting.
Old Mar 21, 2015 | 01:15 PM
02EX's Avatar
I did notice when i replaced the engine, on one of the cooler lines for the transmission there was an inline filter. At the time didnt think i needed it so i just went ahead and took it out. After doing this didnt think of there being a chance of a tsb on it. Is this possible that i need to put an inline filter back in there if so what micron rating?
Old Mar 21, 2015 | 01:19 PM
On the 6th generation Accord with A/T, if there was a Honda (non-aftermarket) in-line filter, chances are the transmission has been previously replaced.
Old Mar 21, 2015 | 01:55 PM
02EX's Avatar
Good idea to put one back in? Been about 20 k since it has been removed.
Old Mar 21, 2015 | 02:08 PM
shipo's Avatar
Some will say put it back in, others, myself included, will say don't bother, the filter inside the transmission should be more than sufficient.
Old Mar 21, 2015 | 02:24 PM
At this point, I would agree with Shipo and say don't bother.
RegisWhite
Nov 16, 2018 10:46 AM
gregomyeggo
Oct 9, 2012 04:36 PM
RonJoyal
Jun 17, 2011 05:55 AM
stremboli
Apr 15, 2010 10:18 PM
cheggie
Mar 15, 2007 09:08 PM
