03 Accord Electrical/Engine Hesitates
Can anyone please help! While driving my dashboard lights flicker and sometime the radio goes out then the car loses power. I can hear clicks when this is happening. It's quick like 2 seconds the car usually does not stall. It has before but i can start it and drive home fine. I also noticed that when taking off my car studders a little and when taking my foot off the pedal it brakes by itself. No check engine light. It came on once for about 2 hours and O'Reilly's said its my ECU relay but the light is off now and mechanic can't duplicate the issue when he has the car?
I tried but the check engine light is not on now so there is not a code and they don't even remember me. Today it did it like 5x in a row. I hear clicks and then the dashboard lights up the radio goes out car hesitates for a split second and then poof everything is normal.
Although yours is a 2003 model, see if this thread may give you more info. into the symptoms you may be experiencing.
https://www.hondaaccordforum.com/for...driving-37567/
glennwood55cameo
May 28, 2013 07:52 PM
