Sponsored by:
Sponsored by:
03 Accord Electrical/Engine Hesitates
Old 06-23-2011, 11:41 PM
Elm04's Avatar
Unhappy 03 Accord Electrical/Engine Hesitates
Can anyone please help! While driving my dashboard lights flicker and sometime the radio goes out then the car loses power. I can hear clicks when this is happening. It's quick like 2 seconds the car usually does not stall. It has before but i can start it and drive home fine. I also noticed that when taking off my car studders a little and when taking my foot off the pedal it brakes by itself. No check engine light. It came on once for about 2 hours and O'Reilly's said its my ECU relay but the light is off now and mechanic can't duplicate the issue when he has the car?
Old 06-24-2011, 12:14 AM
Go back to O'Reillys and have them give you the actual code. The code starts with the letter P and has four numbers, like P1234.
Old 06-24-2011, 01:17 PM
Elm04's Avatar
I tried but the check engine light is not on now so there is not a code and they don't even remember me. Today it did it like 5x in a row. I hear clicks and then the dashboard lights up the radio goes out car hesitates for a split second and then poof everything is normal.
Old 06-24-2011, 02:28 PM
Although yours is a 2003 model, see if this thread may give you more info. into the symptoms you may be experiencing.
https://www.hondaaccordforum.com/for...driving-37567/
Old 10-19-2016, 10:39 PM
I had this exact problem with my o3 accord and it turned out my alternator was bad. Even though I had it replaced my dash still flickers when I'm on my break for long periods of time. Hence the whole reason I'm on this forum lol
mike789r
11-12-2014 10:15 AM
glennwood55cameo
05-28-2013 07:52 PM
moontruggy
12-12-2007 04:33 PM
scottalesibowm
02-22-2006 10:39 PM
silverbullet00
10-13-2005 01:04 AM
Quick Reply: 03 Accord Electrical/Engine Hesitates
